syncing help desperately needed
3 replies · 1,764 views · Started 09 November 2005
we have 3 Nokia 9500s that we can't get to sync with Outlook. They worked OK for a while and now they either won't sync at all [despite trying all the settings adjustments] or they sync random appointments. Does anyone have ANY ideas on what we can try to fix this? 😮
1. connect ur phone via data cable or BT to your comp.
2. open Sync Settings
3. click on create new settings & follow the steps to create a new sync setting.
4. now try & sync
if this does not work.. you will have to do this..
1. uninstall pc suite
2. restart comp
3. install pc suite
4. sync now.
