Joystick very hard to control
2 replies · 1,846 views · Started 15 November 2002
Has anyone else had the same problem?
I seem to find the joystick/nipple very hard to control when playing games or even just navigating the menus...
Anyone done anything to correct the slippyness of it?
I know what you mean by slippy!, Sometimes if you use if for long periods it can be very hard to use.
Try wearing one of the those "rubber fingers" (The ones for counting paper/money) that should sort you out, you may get some funny looks though!
Shame you cant get the replacment nipples like the ones for toshiba laptops, they have little bumps on them so it is easy to move around :cry:
