SmartMovie
13 replies · 50,297 views · Started 09 November 2005
Summary: Competent and very reliable video encoding system, let down slightly by less than stellar performance of the player utility and the interface from hell.
err... if you read my text, you'll see why I didn't like the other systems. To name them, though, I've also tried DVD Player/Lathe and Mobile Media Maker.
Which systems did you have in mind?
Steve
I've used smartmovie for all my s60 handsets and even the 7710, and its worked great, but for some reason it hast just worked for me on my 9500.
the film is always so slow and the audio offset too much from the action. so for the first time i tried the Mobile Movie Maker from Makayama Software and i was reallly impressed.
The conversion interface is bare and basic for the more knowlegeable user and i would hope future versions provide more in-depth options. The fact is i found that it worked perfectly, so much i almost cried and wondered why suffered for a month with Smartmovie.
I paid for the privilage and am enjoying Mobile Movie Maker so far.
thanks for the great review it sums up the smartmovie converter well,
ive also been using it for my 6680 for the last 6 months or so, and so many people have been impressed, baffled, etc, on how a mobile device can produce near dvd quality!
one querey i would have about the converter is, for me it is using 100% cpu to encode a full movie, and taking into account im using a topend pc i find this a bit strange, when using imtoo 3gp or similar prog. it only uses 50/60% maximum. Any ideas on this thanks sean
SMC version 2.76
"so for the first time i tried the Mobile Movie Maker from Makayama Software and i was reallly impressed.
The conversion interface is bare and basic for the more knowlegeable user and i would hope future versions provide more in-depth options. The fact is i found that it worked perfectly, so much i almost cried and wondered why suffered for a month with Smartmovie."
i have also bought the (now called) Nokia Media Suite but at first it seems to work perfect and produce a real nice picture and sound but it only convert around 30 minutes of the DVD. I have emailed twice the tech support people but they will not answer me so the money i paid was for nothing
forkart wrote:Thanks for your review. I use yasa video converter to do video conversion. It also works fine.
[yasasoft.com
why can't i acces this link?:con? is something wrong with it?
Hi Guys,
I am using Smartmovie 3 years ago. I converted many dvd's videoclips for my 9500 and now for my E90 too. Unfortunately it does not support to make full wide screen like the 9500 and the E90 has.
Last week I found the solution. I found a free solution. Mediacoder is a free project. With mediacoder you can convert dvd quality movies even for the 800x352px E90's screen resolution. I tested to convert to 3gp format. The result is excellent.
You can adjust the deepest options possible (audio codec, video codec, mux, scrren cop, video effect and so on.
I have the preset for the E90, I can post later if somebody needs it.
Also free solution is Divx encoder wich is also free. If you register at go_divx_com and get a fee player for your mobile, wich has almost the same features that smartmovie has.
Swingerman
Good app................ previously, I used it on 6600 (abt 2 yrs), n now im using it on E50.... But Still, i cant find any difference btw DivXPlayer n SmartMovie....(except the XviD and DivX Codec Support).
after i install and open this smartmovie it is asking connect to internet
so i press no and switch off and then switch on my mobile
after that also it showing like that
can u plz help me to open this .........
* Standard AVI format, allowing you to preview converted files on your PC
* Also plays MP4V, FLV and 3GP file formats
* Player uses the phone screen in portrait or landscape mode, utilizing the full screen size of the device
* Rescaling of video to utilize the full screen area
* Support for subtitles - allowing you to watch movies in different languages
* Friendly PC converter - preview videos on PC, select parts you want to convert, change conversion quality
* Converter supports DirectShow codecs, so you may use video codecs downloadable from the internet
* Fast conversion; on a standard PC conversion is 5x faster than the video clip playback time.
You'll convert entire movie in just a few minutes
* Quality rescale algorithm in player, delivering best possible picture quality
* Customizable video player (brightness, language, volume, and more)
* User-friendly interface - watch movies, don't waste time configuring obscure settings:con?
😃:con?:con?
