alternative ways to backup 9210
2 replies · 2,329 views · Started 15 January 2002
Are there alternative ways to backup 9210, since PcSuite brings up problem with no error code...
same with back from 9210 via filemanager.
can I move the a folder with contacts, tasks, calendar.. etc.. to the pc and move them back again to 9210. or better can I restore in some way from data folders from pc where I moved them..?
thnx
hi there..
I have a problem with the backup prog.
when I first used the backup, the prog copied my SMS folder together with all the system and stuff.. then I had some problems and I formated the C and D, installed a complete new sys, and all the SMS and stuff where gone too... now I have some new ones stored in my 9210... the problem is
how can I copy the old ones (in the PC) into the folder of the new ones (in 9210) without overwriting them or somethin' like that ? I really dont have a clue about SMS file type.. folder.. name...
thanks
My english is not good....but you will restore SMS and Mail?!?
When you have your SMS folder on D-Drive (D\System\Mails) Format c-Drive......now you can startup your 9210 and reinstall all applications.....then CHANGE under Messages the folder from c to d-Drive and now all SMS and Mails are "restored"....
You need the complet folder \system\mails!!!
