Is it possible to disable camera activating by twisting the display 90 degrees?
i want use another camera program!!!!!
it is possible to resist the activation of the camera while you twist. but the only thing you have to do is just twist the screen to 135 degrees i.e make the screen flat with the keypad in a upside down position . now select your alternate cam and again twist it back to the usual camera position . then the inbuilt cam doesnt open. try it 😊
