Hindi Font
6 replies · 5,245 views · Started 13 November 2005
How to put hindi font in 3230. i cant read the messages which i receive in Hindi language.
Hindi is the national language of INDIA.
some network operators in india support sending SMSes in Hindi which he is not able to see properly. Can anyone suggest the solution
Easiest solution is to get a phone model with Hindi support built-in. Anything else is more difficult (or doesn't exist/is not possible).
N/A wrote:Easiest solution is to get a phone model with Hindi support built-in. Anything else is more difficult (or doesn't exist/is not possible).
Well, how about change the language like my country does, some of phone's shop provide for changing language. Something like to patch the language.
You want the phone to display messages in ENGLISH & HINDI, correct?
it CAN be done... I'll just work on it & have a solution for you shortly. Watch this space. 😊
jagjeetpradeep wrote:You want the phone to display messages in ENGLISH & HINDI, correct?
hey thx jaggi......waiting for ur reply.
