I have just had a go at creating a theme for my N70 with the theme studio 2.0, it was extremely difficult compared to usual as the software isnt really laid out for the theme type of this phone but...
I managed to create a theme, almost perfect except for one thing, I can not find how to set the Navi pane background in theme studio, the one that has the tabs on for messaging and has the date in the idle mode. When i transfer to my phone this shows up blue getting lighter as it goes towards the left. It also showsi n the menus. It seems that the white gradient bit I have in there is just fading it out towards the left but why is the blue here? It does not show up in theme studio and I have tried replacing all parts of the theme.
Any suggestions would be a great help, I can post a screenshot if need be.
I have found the problem, but can't find a fix. THe problem is that in theme studio when i click the navipane background to edit it, it will not take me to it and allow me to change it, it says one is saved (has a tick) but i can't get to it what ever i do. I'm going to try transferring every indicidual image manually to a new theme and see how that goes, any help would be appreciated. Thanks
click the layer button add 2 new layers the delete the original layer then save repeat the same steps for the next navi bar. Is your battery and signal icons working mine keep showing up stock
griffithstrife wrote:click the layer button add 2 new layers the delete the original layer then save repeat the same steps for the next navi bar. Is your battery and signal icons working mine keep showing up stock
That doesn't work, i can't get to it at all. But yeh, my indicators do work, althoough the THeme Studio isnt very reliable, each time i recreate the .sis Something new doesnt work quite right in the theme or is missing. GUess we should wait for an update or something. :redface:
