I got the Yahoo Mail settings texted to my 9500 and got it all set up ok.
However, when signing in I have to input my username and password twice before it moves to the next step in the procedure.
Any suggestions to sort this??
Yahoo Mail
Are you trying the mobile version? If not, give it a try...
and
to go directly to mail.
Yes, it's the mobile version I'm using.
thanx 4 all :icon14: 😉
So you're using the mobile vserion! I have nothing to say but the usual suggestions:
Try logging in from *another* 9300/9500 and see if the problem persists.
Have a friend who has a Yahoo ID login using *your* communicator and see if he faces the same problem.
Create a new Yahoo ID and try to log in with it using your communicator.
I'm hoping all --or some-- of the above will help you isolate the problem and determine if it's your communicator or something to do with your Yahoo account.
Good luck.
