Nokia6630 updated firmware
6 replies · 3,558 views · Started 15 November 2005
the V5.03.08 was out last 17th of august 2005. Was there any known issues or bugs regarding that latest firmware? And I also want to add if I bought a Made in Finland phone, the battery thats with the package should be made from what country. Info pls. Thanks!🙄 [SIZE="4"][FONT="Arial Black"][/FONT][/SIZE]
I've also noticed that the color palletes on each themes cannot be change same as on version 4.38, and when i checked the firmware version *#0000# there is a nokia 6630 text below it version and date. do you encounter the same?
i updated from 3.xx to 5.xx and a bug with bad sound on headphones and random restarting of the phone has been fixes. but the amount of free ram has dropped! so if the 4.xx firmware doesn't show any bugs just don't update!
btw: the option to save or delete written but unsented sms/mms on closing the app should also be in the 4.xx firmware
does your new firmware have a NOKIA6630 below when you look at it firmware version pressing *#0000#, and why cant I change its color palette?
yes, it shows the device name! with the 6630 there is no way anymore to deactivate themes, to have the s60 standard look. so changing the color palette has nearly no use. currently i can see only in fexplorer a differcange when changing the palette.
[SIZE="4"]is there a factory released version 5.03.08 of the Nokia 6630? coz I think that you can only acquire that firmware version thru nokia upgrade... anyone knows?...[/SIZE]
