Nokia6630 updated firmware
2 replies · 2,213 views · Started 15 November 2005
the V5.03.08 was out last 17th of august 2005. Was there any known issues or bugs regarding that latest firmware? And I also want to add if I bought a Made in Finland phone, the battery thats with the package should be made from what country. Info pls. Thanks!🙄 [SIZE="4"][FONT="Arial Black"][/FONT][/SIZE]
I found the problem in this version, if you set the function summary after call to on the phone will reset after you hang up to call 😞
thanks for the reply tosapol9! just want to know what's on the displayed screen when you press *#0000# to check your firmware coz mine displays NOKIA 6630 bellow the 5.03.03 15.08.05 RM-1.
does yours displays the same way too? thanks! keep it up!😊
