Hi folks,
maybe it's a silly question, but I am really worried. I have a "traditional" Ngage and now I bought a new QD. I wanted to move my list of contacts from one to the other (300+ names, so I would like to avoid to bluetooth them one by one).
I made the backup with a memory card on the original, and I tried to restore on the new Qd. it didn't see it. so I did a backup with the QD (having written just a single entry), I connected the card to the PC, and I noticed that there were two different file. one was "backup.asw", the other "ngageqdsomethin.asw". I changed the name of the first with the second, I inserted the card in the Qd, and this time it saw the backup and I restored it.
Now, on the QD I had the list of contact, but something went wrong since I couldn't use any menu (it always said: "no memory error" or something like that). I had to use the *#7370# trick I found on this forum, to reset the Ngage. (It even changed the menu in the bottom, replacing "play" with "messages", as it was on the original Ngage).
the question is: do you know if there is a way to pass all contacts from one mobile to the other? They are almost the same mobile, and have the same engine...
thanks in advance
Neon
