Lifeguide Now Available for Series 80
1 replies · 1,345 views · Started 16 November 2005
Steve's been busy on some OPL applications again (that'll be the 'rapid' in rapid application developement), and has brought his Lifeguide app over to Series 80 - it's a freeware bible-based guide to 'life' based on the sections you usually find in the front of Gideon hotel bibles.
You're not kidding about the 'rapid' bit. Just as an experiment, I decided to forget all previous code and example apps, and to write LifeGuide from scratch. The coding itself took a total of two hours. Plus another couple to mess around with importing my text database and the image. But essentially I started writing the program at 9am and had a finished SIS on Handango just after lunch. 8-)
Steve (biggest OPL fan in the known universe) Litchfield
