Hey,
I bought my N70 which came on Vodafone.
I am now using my O2 Contract sim in this fone, I downloaded the O2 active seetings from O2 for the 6680 hoping that they would work.
I've had no luck so far it just keeps on trying to resend every 10 mins and failing.
Anyone have MMS working on O2 on the N70?
I'm starting to wonder wether I should have just kept my SE W800i.
I use theses on my N90
text message settings: Message centre o2 sms
msg centre in use: o2 sms; message sent as text; prefered connection GSM/UMTS
multimedia message settings: mms creation mode Guided; Access point in use o2 mms;
These work for me hope it helps.
You should be able to run the 'settings wizard' application on your phone and it will do the settings for you, or go to nokia.co.uk go to the support pages for your phone and order the settings and they will send them to your phone over the air.
Rgds
Will
