sync: p910i and Lotus Notes 7.0
1 replies · 4,461 views · Started 17 November 2005
Hi Folks,
Has anyone managed to get the sync to work with Lotus Notes 7.x.
I have not managed to make it work and it's bugging the hell out of me.😮
It's only the calendar that is affected so far, the contacts work fine. (I don't sync anything else).
If anyone has an idea of how to make this work I can test it with no probs.
All ideas greatly received.
Just tried this and it worked!!
Run Regedit.
Under
HKEY_LOCAL_MACHINE
SOFTWARE
LOTUS
NOTES
You will find a folder named "7.0".
Rename this folder to "6.0".
Close Regedit.
Connet your p910i and Start SonyEricsson Sync Station Settings and select Lotus Notes 6.0 for calander, task etc...
Frode
