Can i connect the phone with pc without pc suite, cos i have win me. I have 6260 and dku-2. So can i make phone like a usb storage or something?
Can I have connection without pc suite?
You can use your phone as an infrared modem, or Bluetooth modem (if there's Bluetooth hardware and software on your PC supported by WinME).
You can also send files over infrared or Bluetooth to the phone's Inbox.
That's about all you can do without additional software.
There's nothing you can do with the cable, really, unless you upgrade to Windows 2000 or XP.
Ok. Thanks for answer
