i only have fax on my account settibgs... how do i activate sms.. please help.
this is my 3rd time already today to re-format and re-install.
i cant send sms, i think its missing.
NOTE
NOT FOUND
is what always comes up
NOTE
NOT FOUND
Yep it isn't installed, did you install the 2 sis files?
yes i did, still the same though. is there another way to format the device completely other than SHFT+CTRL+F?
thanks for helping me out, i really appreciate it.
why dont you check your SMS center number and verify it by your local cell phone operater..
click on messaging > menu > tools > account settings > sms > edit !
download from nokia the appropriate software for your version.
format, and reinstall all_nokia9210data.sis -- this should contain the messaging app.
I had this same problem a while back with another application, all you need do is install the "Notes" sis file which can be downloaded from nokia depending on the software version you have on your phone
Ver 3.54 or 3.62 http://www.nokia.com/cda1/0,1080,3091,00.html
Ver 4.13 http://www.nokia.com/cda1/0,1080,3093,00.html
