Hi there,
I'm quite new to this forum and also use N70. I've just installed 'KeyLocker' and saw that it has a feature to add to 'Go to' so I did but after that my 'Go to' doesn't work anymore.
Is there anyone out there having the same experience like me?
Need advise how to get my 'GoTo' back to work.
enter1
Yes uninstall the app and use the auto keylock on the phone !! It works very well .
i didnt realise that the n70 had an auto keylock feature.. if so how do i access it?
kp1 wrote:i didnt realise that the n70 had an auto keylock feature.. if so how do i access it?
It doesn't... but it does have an auto lock phone feature, where once locked you then have to enter the 5 digit security code to unlock the phone. Look under: Tools... Settings... Security... Phone and Sim... Autolock Period.
The default security code is 12345 and you can change it to whatever you want.
S.
Thanks for advise, however the reason I installed the KeyLocker app is to lock the key pad not exactly want to lock the phone.
I uninstalled the app but my "Go To" still doesn't work. So really need help.
Thanks again
hi there!
i thought i'm the only one encounter such problem.. haha.. for me, it's a software called 'FullScreenCaller' by SymbianWare. i called up Nokia Care centre and even wrote to SymbianWare. both can't help and SymbianWare said this software is not meant to be compatible with N70.
anyway, this is what you do
1) install FExplorer (or any application with similar function)
2) locate C:\System\Favourites
3) locate the file with 'Keylocker' (or resemble this software; think it's *lnk file type or something like that).
4) delete it.
ta~da!! your 'Go To' is revived!! 😃
Hi Sian, I've followed your advise and it's now back to normal.
Great advise, thanks a lot
No prob! Glad to know that it's resolved.
jjlkeylock_2_0
works perfectly. autostarts at bootup.
Sian wrote:hi there!i thought i'm the only one encounter such problem.. haha.. for me, it's a software called 'FullScreenCaller' by SymbianWare. i called up Nokia Care centre and even wrote to SymbianWare. both can't help and SymbianWare said this software is not meant to be compatible with N70.
4) delete it.
it's great to have you guys..
it worked perfectly for me too..
thanks!!:icon14: 😊 everything is back to normal
