HELP- 6600, pc suite, outlook 2003
2 replies · 2,535 views · Started 20 November 2005
Hi everyone,
I'm having trouble with the sync between my nokia 6600 and pc suite. i can see the phone on my pc and sync starts correctly.
after about one minute os sincronisation it says error with"ECTaskScheduler.exe" , the file will be closed.
after one more minute it says error with SCRFS.exe, the file will be closed.
after one more minute... error with "expolrer.exe" the file will be closed.😮
I manage to do the sync but i can do it then have to restart my pc.😡
any hints to solve the problem?
I'm using
- the stadard bluetooth software supplied with the hamlet BT device (it is a blue soleil, I' already have tried to download a newer version but same issue)
- outlook professional 2003
- win xp sp2
thank you, U really save the life of my phone (it will B soon trown out the winwodow!)
D.
p.s. pls forgive spelling errors 😉
At least u got ur pc suite running.
i cant help u cause my pc suite aint working with bluesoil.
what version using?
What does mrouter say on com ports?
Does the 6600 work with the pc suite at all?
I`m having loads of problems....if u cam email me some screenshots of ur bluesoil and mrouter i`d apprecaite it.
Please also tell me what systems service packs u have installed?
The 6600 works only with its own PC Suite, not the newer generation PC Suite 6.* for newer phones.
At the time the 6600 version of PC Suite was created, BlueSoleil Bluetooth drivers were not available and are not supported. In fact, BlueSoleil support first appeared in the latest PC Suite 6.6.18 which was released a couple of months ago (and as stated, does not work with the 6600).
The old 6600 PC Suite only supported the ancient DigiAnswer/Socket Communications and Widcomm Bluetooth drivers, if my memory serves me right.
With newer IntuWave m-Router bits (than what's in the 6600 PC Suite) newer Bluetooth hw/sw might work, but I haven't tried such.
