:frown: how can i see the systems folder if im using card reader? it's hidden upon formating my mmc with my engage qd. pls help. TY IN ADVANCE
Help!: Card Reader Problem
If you are using the card reader on Windows, see "Tools" (menu) > "Folder Options..." (menu entry) > "View "(tab) > "Hidden files and folders" (setting in "Advanced settings" in Windows Explorer. The rest should be obvious.
THANK YOU SO MUCH! I REALLY AM NOT USED TO ALL THE INS AND OUTS OF PC'S. NOW IT WILL BE EASIER FOR ME TO DOWN LOAD FILES INSTEAD OF CUTTING AND PASTING IT IN MY FE EXPLORER:icon14: 😊
