Hi all,
got this wild a920 flashed to a925 over here in Canada. love the phone, just trying to learn how to use it. put in a 1 gig sd card to start with. have connected to my pc via usb but any prgs i tried to install didn't work. can this thing work as a gps?? any help or a starters point would be greatly appreciated. thanks.
can the a920/925 connect to a network or wireless network to browse the web?
luke905 wrote:any prgs i tried to install didn't work.
In what way did they not work? Did they install? Was there an error message?
Yes, but only with applications installed on it. You can't use it as a GPS for another device, such as a computer. There are several GPS applications available, such as Find the Place (free), Wayfinder (commercial) and nhGPS (commercial with free trial).
If you mean WiFi, or WLAN, then no. But it does have Bluetooth support, so it can use that to surf the web. The speed is lower than 802.11b of course, and also the range is worse. But then again, it's a 3G phone, so it's made for use on the internet as long as you have an UMTS carrier where you're planning to use the phone.
