This guide will help you to connect your N-Gage or other Nokia Series 60 phone to the internet so that
you may connect to the N-Gage Arena or just browse the internet all without having to use your phone service.
Most service providers charge a fee for surfing the web or using any data services on your phone. After
completing this guide you will be able to do any of the above without any charges and with the speed of
your home internet connection you'll do it faster!
1ST BEFORE READING ANY FARTHER....YOU MUST ALREADY HAVE PCSUITE SUCCESFULLY INSTALLED!!!
First make sure that your PC Suite works with bluetooth.
DO NOT and I repeat DO NOT!!! Just configure your mRouter to connect on the same serial port as your bluetooth
usb dongle. (BECAUSE IF YOU DO YOU WILL GET THE ERROR MAXIMUM BLUETOOTH CONNECTIONS REACHED!!!!! )
On the phone:
Download the gnubox application and install it on your phone.
http://www.raywalk.com/upload/1/8/gnubox.sis
FIRST YOU WILL HAVE TO SETUP THE CONNECTION WITH YOUR PC SO:
Setting--->Connection--->GPRS--->accesspoint; HERE FILL IN THE NAME OF YOUR PC!!!!!!! Do not forget this!!!!!!
Create a new Access Point on the phone
(Settings--->Connection--->Access points--->New access point--->Use default settings)
Name: Bt Data Bearer:
GSM data: (This is NOT GPRS!! you have 2 change it!!)
Dial-up number: 2222
Username: RasUser
Promp password: No
Password: pass
Gateway IP Address: 169.254.1.68
Homepage: http://www.google.com/wml (or anything you want)
Install gnubox.sis on your phone.
NOW YOU PUT ON YOUR BLUETOOTH.
Run the gnubox application and select
Options--->2box Direct--->Bluetooth.
Now the gnubox application WILL SEARCH FOR YOUR PC!!!!!It should list the new settings and switch to a light
BLUE BACKGROUND if you see this everything is working fine!!!!!!
That's it! Now start the game you want to play online, and then select the N-gage Arena mode. It will now ask you which
accesspoint to use, so select the Bt accesspoint when you want to connect and it should work fine.
Happy browsing,
Thanks to Fromanotherstate for the original info😊
