are there special apps for the nokia 6630?? cos i have tons of apps that used to work on my nokia 3650 and now do not work on this phone.. every time i try to install one of the applications i get the ''security error unable to install". does anyone know the solution for that??:frown:
apps do not work on my nokia 6630
remove the security certificate
http://3lib.ukonline.co.uk/n6600.htm
Open up your device
By default, some 6630 and other modern Series 60 smartphones come 'locked down' in terms of the applications they'll accept, installing only those that have large companies behind them, able to afford the expensive 'signing' process. But there are hundreds of other great applications, many of them free, that are 'unsigned'. Don't worry about this (see my malware article to put your mind at rest). Just go to 'Tools | Manager | Options | Settings' and turn 'Software installation' "On". (While you're in this dialog, make sure 'Online certif. check' is 'Off'. You can now install any compatible program without being blocked by spurious security warnings!
thank u very much u really put me in relief
