Problem with SX1
3 replies · 3,074 views · Started 25 November 2005
Hello,
I have a problem with incoming SMS messages. I can't get them, because when it comes i receive the message: not enough memory to receive SIM messages. Delete
some data first! Afterpresing any button - there aren't any message in my inbox.
First of all - l am shure that i have a place in my mobile, because the drive c has 3000kb free, and SIM card is free also.
As i know SMS messages are stored in drive c, so why that messages tells me about SIM?
Please, could you recomend possible solution for that problem, or someone heard about such problem?
Thanx
I'd still try to see if the SIM messages (I think on the SX1 there was a separate app for that) shows something.
Try also another SIM card in the phone and see if it works.
If it is something on the phone, you could also reset/reformat the phone, or update it with the latest firmware versions that Siemens has created for it. Those operations will wipe the phone from your own data, though.
Only after (or if) those fail to provide results, would I consider a repair shop trip necessary.
Thanks for the answer 😉
I've made most of the things you've recomended. Formated the phone few times, also firmware is the latest (15 for sx1 as i know). Sim card is also free (there is posibility to check that in Messages settings).
Only i have't tryed to use another SIM.
It's possible that this is the problem of my mobile net Operator, because i can get SMS's from other Operators.
So after that - the only way to call them and go to their repair shop, as you recomended...
