Backup Messages
1 replies · 2,020 views · Started 28 November 2005
Hello,
I posted this at sendosmartphones as well but I'm not sure which forum is read more often, so my excuses for "double-"posting 😃
I want to extract all my messages (SMS) from my SendoX (not email), I'll be migrating my main phone number to a new phone (Windows Mobile 5) and want to take the messages (500!) with it. And keep my SendoX for my 2nd number.
Is this possible at all and if it is how can I do this?
If it involves some technical work, I don't mind since there are a lot of important messages on my SendoX right now.
Thanks in Advance!
The attachments that are in the messages can be easely copied with FExplorer from the inbox out to a memory card.
You also should look at Oxygen Phone Manager for Symbian. It can copy all messages, contacts and calender to your desktop. I use it for backup 😉 because i also like to look at Contacts and the other things on my PC, since i have no Outlook.
Link: http://www.opm-2.com/Symbian/
I think it cannot them copy back to a Windows Device, but there should be some possible to look at the data created from it and convert it accordingly.
Cheers, murphy 😊
PS: Did you sell your Sendo?
