How Do I Hide A Java App?
3 replies · 1,975 views · Started 29 November 2005
I have an N-Gage that I sometimes let my kids play. I have some java apps that I would rather them not mess with, and I don't want to constantly hover over them while they're using my phone. Is there a way to hide or move a java app to another location so it:
1) doesn't show up in the "Apps" menu, and
2) is still easily useable by me?
Thanks so much for your help!
Install them on a memory card, and remove the card before you give the phone to somebody else.
That would be a great idea if I had a memory card, and if I could part with Colin McRae Rally long enough to use it 😎
Any other ideas?
N/A wrote:Install them on a memory card, and remove the card before you give the phone to somebody else.
Money can solve the first problem. For the second one the fix is more self-control. 😉
I don't know what happens, if you'd turn on the "hidden" attribute for the .jar file of the Java program with FExplorer (http://www.gosymbian.com/), but if you decide to experiment with it, let us know...
