Im developing for Symbian 9.1 and need to link with a third party library. Previously (when using 7.0s) I
could just specify the library in the MMP file and the build tools would happily link with the file.
Now, however, it doesnt seem quite so simple. We have had the library recompiled for ARMV5 but are still
experiencing problems linking with it. I notice from the SDK help that the file format in 9.1 for binaries has
changed and needs to be in the E32Image format. There seems to be a tool in the SDK (elf2e32) that is able to
generate the library in the format required but when we try and use it (supplying the third party library we
have been given as the --elfinput= parameter) we just get the following error:
"elf2e32 : Error: E1005: ELF file aacommon.a is not 32 bit."
Has anyone had any similar problems when trying to use elf2e32 or when using third party libraries on OS 9.1
Any help is greatly appreciated
Many Thanks
Jad
