9210 Bounce - Han anyone finished it
23 replies · 6,617 views · Started 16 January 2002
OK I am a self confessed Bounce addict. Level 17 took me AGES but I am determined to finish it (Im on level 21).
Has anyone out there finished it? Is anyone else on level 21? Is anyone stuck on the last two hoops of level 17? <grin>
Seems like quite a lot of people are stuck on Level 21 (including me).
anyone intrested in producing a map (ie with screenshots)?
I finished it a couple of weeks ago. It is INCREDIBLY hard. It is at least as hard as levels 1-20 put together. To have any chance you need to make a map of the whole level (using screenshots), print it out 20 times, get a coloured pen. and plan your escape!
Good luck!
Tony
Hi there Bounce fans! User posted image
I have done a map of the Bounce level 21. It has hundreds of screenshots and it is done with html. I am not sure whether or not it should be published cause it makes the completion of level 21 too easy.. User posted image
For me it felt pretty boring completing the level 21, cause there are no more levels after that.. ;(
If you want the map, please reply and I'll send you the URL to it, but I must warn you, it really makes it too easy to complete lvl 21!!!
- JAska
OK I finished bounce level 21 3 months ago and now im gettring bored - can we PLEASE have some more levels Nokia
Tony
okk can you help me get passed level 17! like u said i cant find the last two hoops! i've bin stuck on it for ages now and im really confused! pls pls pls help me!
Hi there
Please mail me at [email][email protected][/email]
the link to the Level 21 Map.
I would really appreciate it. i have been battling with this level for a month now and its killing me.
- JAska
N9210 wrote:Seems like quite a lot of people are stuck on Level 21 (including me).
Well!!!!"where r u stuck on level 21.may be I can help ya.Let me know
HI
Read your mail and it sounds exactly like what i want 😊
could you mail me the url to your screenshots
My ID is [email][email protected][/email]
Cheers to all the help
L
- JAska
I need help getting the top rings in Bounce Level 8 in the blue extra bouncy area. I can't seem to get to the top to get those rings.
