Extended internet by Psiloc
2 replies · 2,829 views · Started 02 December 2005
I have a 9290 and the description says that this program will connect via GPRS throught IR, landline modem etc. Has anyone used this and can you get on the internet faster then with the normal GSM facility???? I question really is, is it worth getting????
Thanks,
Bob
Connection speed depends on many things (like modem model etc.).
In my opinion GPRS is faster than normal GSM facility.
Remember that you can use all Psiloc applications in the trial mode- for free for a short period of time- to check if it is working fine.
More information about Extended Internet:
http://www.psiloc.com/index.html?id=187
My main thought was, and I probably didn't say it very well, will this program give my 9210 GPRS speed some how??? And do you have instructions how to set it up please. It gives lots of options, just trying to figure them out.
Thanks,
Bob
PsilocSupport wrote:Connection speed depends on many things (like modem model etc.).
