Phone lookup - ala windows smartphone
3 replies · 1,948 views · Started 02 December 2005
I'm looking for an application that has the same behaviour as what's available on windows mobile smartphones ie:
1. you're in idle screen
2. begin to type 3(def), 5(jkl) & 6(mno) and it looks-up all names and last names that contain either of the combinations (djm, dkm.... flo...)
With this method, I find people in my addressbook of 700 contacts in seconds
Does this exist? I think i had seen such an app a while ago but can't find it back.
Thanks for your help.
Try ALON Contact Guide Pro. It has most of the feaztures u look for, but it is still a little buggy. (I use version 1.02)
Good luck
