Nokia N70 is broke, what shall I do?
1 replies · 1,863 views · Started 03 December 2005
My N70 has developed an odd fault overnight.
The 2 buttons above the Answer Call/Cancel Call buttons no longer work, neither do the left and right directional buttons.
So basically I cant access any applications on the left hand side or right hand side of the menu. Also cant use the quick link buttons.
Should I go back to Vodafone and moan?
Its really annoying me, first the bloodt memory card isnt compatibel, and now this....🙄
i guess you've tried all logical steps so far... you could try a hardware reset *#7370# - THIS WIPES ALL DATA FORM YOUR PHONE! so back it up first 😉
i am NOT advising you to do this unless you feel comfortable doing it.. but i guess if the thing is knackered then you have little to lose!
you can read more here http://discussions.nokia.co.uk/discussions/board/message?board.id=hardware&message.id=13&view=by_date_ascending&page=1
you could always take it to a Nokia Service Centre... failing that take it back to Vodamoan and get one of them to bend over and drop kick it where the sun don't shine 😮
