Is there anyway you can upgrade the to 3.0? I know you have to have symbian 9.0, so then do you would i have to upgrade that also?
P910a UIQ 2.1 -> 3.0 Possible?
No upgrades like that are likely. And due to hardware differences the exact same software as for the P990 will not be usable directly on a P910.
what about price of SE P990i? I can't buy it in Bosnia yet, but I would like what is price in your countries... Thanks in advance
Same price as the P910 launch price? Or more expensive, if you look at the Playstation3....
www.expansys.com - UKP595
www.mphone.co.uk - UKP630
www.mobilefun.co.uk - UKP599
www.play.com - UKP599
www.pixmania.co.uk - UKP530
