guys anyone knows how to change the splashscreen in nokia 9500??
i located the file at z:\system\data\splashscreen.mbm, i change the default splashscreen by mbmwhizard and recompiled it.. the problem is.. dont know where to put it? coz drive z: is read only. have any idea on this guys??
nicola13 wrote:guys anyone knows how to change the splashscreen in nokia 9500??i located the file at z:\system\data\splashscreen.mbm, i change the default splashscreen by mbmwhizard and recompiled it.. the problem is.. dont know where to put it? coz drive z: is read only. have any idea on this guys??
Because drive Z is in the firmware, The only way to change the splash screen is to get your file loaded into the firmware,
But I doubt that any Nokia Service Centre will do this for you as it would make a custom firmware version,
I think the networks get some tools from Nokia that allow them to change the firmware (For branding purposes) but they would either be expensive or for Operators only,
Sorry,
Carl,
hmmnn... there must be another way... coz it have a C: drive that is read / write property.. it has to be some UID linkin or somethin...
oh well, thanks for the info man.. 😊
