is it possiable to change the start up animation to a gif image or something, if so what program do uuse or can it be done without any programs
thanks 😃
thanks 😃
yeah that would be cool i'd like to put these images on,
any one no how
Go to phone settings and there to welcome note or logo
you can set a picture there. or text.
is it possible to animated images?
do they have to be a certain size?
thanks 😃
I think that it cant be animated, havent tested it myself though.
And the size should be 174x208.
cool thanks, i'll try later n let u know
cant now my phones on charge 😮ops:
cool it works, but u cant get animated images, shame would of looked cool
yeah jus tried it, cant get gifs to work
heres the image im using still looks cool
i'm using this
If you save the picture as a multi frame MBM, you should find that it will then animate.
coolsonics!! new vocab 😃
[quote="TANKERx"]If you save the picture as a multi frame MBM, you should find that it will then animate.[/quote]
Thats cool, I thought it would, but hadnt had time to try it out.
thanks 😃
:cry: no it doest work with my 7650 :cry: what a pity, i would like to see an animated pic in the morning when i start my phone..
i mean the default start up image is animated right? it should work!! i just don't know how 😃
ok, which program lets u save in "MULITI FRAME MBM"[/quote]
Guys how can i convert a gif to MBM?
[quote="Sonic"]ok, which program lets u save in "MULITI FRAME MBM"[/quote][/quote]
I hope this helps a little.
I hope this helps a little.This is actually a tutotiral about creating icons,but it might help.
http://homepages.nildram.co.uk/~nicko/5icons.htm
I have tried it and i was only able to convert the ryu image in to single frame grey scale or binary mbm,so have a blast,if anyone can get it working let us know.
I haven't tried this, but this may be what you need to do;
Convert your image to a multi frame MBM and then, instead of using the UI to select your startup image, save it as C:\System\Data\Backgroundimage.mbm - that way, the system won't try messing with it in any way (which it does try and do when you go through the UI).
Is this thread in some kind of a worm/worp/time hole,its really strange.
[quote="TANKERx"]I haven't tried this, but this may be what you need to do;
Convert your image to a multi frame MBM and then, instead of using the UI to select your startup image, save it as C:\System\Data\Backgroundimage.mbm - that way, the system won't try messing with it in any way (which it does try and do when you go through the UI).[/quote]
I tried doing this with xnview but i havent suceeded so far,i cant even save it in colour,just gray scale and binary,and i havent seen an option about multiframe mbms.Since i got this app just yesterday i might be doing something wrong.Anyone else?
