What features would you like to see in the next Skin Wizard? (In priority) I can think of a lot of options but I would like to program what is needed mostly.
Tijmen
Note:
Skin Wizard 1.0 can be downloaded from
http://www.vangulik.org/tijmen/SkinWizardS80/
customizable icons would be gr8. and all the MBM files (if possible..) like.. the splashscreen.mbm found in Z:\system\data folder..
My wishlist items:
Being able to see a preview of all the changes e.g. changing the colour of the clock shows the change on a mockup of the screen.
Being able to see the current set colours (that it reads from any existing skn file or shows the defaults if no skn file exists)
Being able to edit one or two colours (i.e. not having to set all colours) which doesn't seem possible at the moment (or is it me doing something wrong?).
Remember and use the last settings e.g. skins directory.
You see the default colors in version 1.0 , and you do not have to change all colors, just the colors you need (This was also the case in the previous verson) The preview will be a nice feature I think. Do you use version 1.0?
Tijmen
andygrunt wrote:My wishlist items:Being able to see a preview of all the changes e.g. changing the colour of the clock shows the change on a mockup of the screen.
I just checked and I'm using '0.9 Beta'. I didn't realise it was an older version - downloading now...
A preview when you set the colors would be great
