Nokia N70/Tomtom
4 replies · 2,493 views · Started 09 December 2005
Can anyone help me? I'm having problems getting my tomtom 5.20 to start on my n70. I,ve copied all files from my pc to memory card and then go into files manager to try to activate, but all i get is file not recognised. Can anyone help.
jud wrote:Can anyone help me? I'm having problems getting my tomtom 5.20 to start on my n70. I,ve copied all files from my pc to memory card and then go into files manager to try to activate, but all i get is file not recognised. Can anyone help.
Sounds like there is something wrong with the files or the way you've put it on your card. There should be no need to go into file manager. If it's been copied correctly to your memory card when you insert the card an icon should appear in the N70's menu.
Well, you should have the tomtom, voices, and the Great-Britain-Map folders in the root of your memory card. You also need to copy the ttmobile, and ttnavcontacts folders to the /system/apps directory on your memory card.
If that doesn't work must be something wrong with the files you have.
Thanks alot mate, been trying to get it loaded for a week now. Just got to sort the gps out now.
