Nokia N70 Ring Tone patch file
Sometimes your phone might not ring or vibrate when a call is received. There are a few reasons why this might occur:
If you have deleted your ring tone file or changed your MMC card, the phone may not be able to find the ring tone file and therefore cannot play it. Please ensure that your selected ring tone file still exists on the phone or the MMC card. Complex ring tones (MIDI, AAC, MP3 or WAV files) can sometimes take a long time to load and play. Occasionally when this happens the phone uses a default ring tone setting which.. ..
Read more:
N70 Ring Tone patch file - full story, download, etc
Sincerely yours,
Apoc
My Phone was better before installing the patch. after Installing the patch it does not load and play the ringtone that i have set...but plays the default Nokia tone. :icon13:
ashwathashu; you are totally right!!!! I do not know how can I keep my phone off doing this!!! I uninstalled the path file and still sometimes keeps playing the nokia tune and I want the phone to play the ringtone I selected to play not the nokia tune. If someone here could let me know how to avoid this I would be very appreciated... :con?
Hey i had the same problem with my n70 but mine just didnt do anything but when i got a text it rang and vibrated and i then noticed my 7 missed calls!! I took it to my local vodafone store which is where i purchased the phone and they sent it away for a software update. Only took a few days and it now works fine. I suggest you do the same.
Hope it works out for you, Scott
GerbilChops wrote:Hey i had the same problem with my n70 but mine just didnt do anything but when i got a text it rang and vibrated and i then noticed my 7 missed calls!! I took it to my local vodafone store which is where i purchased the phone and they sent it away for a software update. Only took a few days and it now works fine. I suggest you do the same.Hope it works out for you, Scott
Thanks a lot Scott!!!!! what firmware version you got? I right now have in my phone:
V 3.0546.2.3
18-11-05
RM-84
It is that the same software version you have?
Regards
seems like mine is outdated allready:
V2.0539.1.2
19-10-05
RM-84
You could still try taking back to where you bought it so they can update it. If you bought it recently, i think it is up till a month ago, they will give you a brand new phone instead of sending yours away as long as it is in good condition. If it still dosnt work, then... pester Nokia direct!!
Good luck
Scott:icon14:
