I have a Nokia N70 installed Tom Tom Mobile fine. One small problem:
How do i connect to the BT GPS? Any ideas? Please reply if you can help.
Andrew
Andrew
You need to connect to the GPS using the menu (and / or make sure you are set up in Settings). TomTom provides some instruction with the software on how to do this step by step I believe so you coudl try looking there too.
