Hi all
I have somehow managed to change the font on my N70,, but I dont like it..
ny ideas on how to change it back... I tried restoring defaults, but that didnt work
Thx in advance
Hi all
Thx in advance
How did u managed to do it? Care to advise cos i have been trying to change it without much success.
Thanks!
I guess it can be restored to default by a program call font remover found on SYmbian-Freak website.
Not knowing what i was doing, i downloaded some fonts from a link on a site that showed you how to change fonts and installed them on my phone, i have tried the font remover but it didnt work, i have managed to change them to a different one, but not one i like. At the moment I am trying to convert ttf file into a gdr file with a program called easy gdr but it wont work for me.
Hooray
Well I have got the font I want now😃
Follow the instructions http://nokiafree.org/forums/t71321/h/s.html I had to read it a few times before I got it, but now I got real big fonts and can see my text 😊
Hi Lyntaz...well done on getting your big font!:icon14:
Could you tell me the name of the font, as the download in the link you gave isn't working. Do you have to install explorer and is it difficult for a techophobe like me?
Thanks😉
Hi
I installed fexplorerand font remover and used Easy GDR Creator to create my font,, i have attached my file... I guess you will need to read up to.. i just typed it in google and followed it rom there.
Good 😊 Luck
Thanks a lot. I'll read upa bit on it and let you know if I manage it! Scary😮
