Bluetooth Connection failed - Nokia 3230
1 replies · 1,611 views · Started 11 December 2005
Anytime I tried to connect my PC with my newly bought Nokia 3230 the error msg "Connection failed" popped up. I coud do nothing with PC suite as the mobile phone is not connected. I am using Window XP SP2 and Dell TrueMobile 350 Bluetooth module.
I really cannot figure out where the problem is as I see my PC has all the required system.
Really appreciate any help! Thanks.
:icon14:
well its been a long time and at last thanks to NBS live 2006. why? because nba live 2006 is not running on my computer and i started to wonder wtf is the problem then i searches the net why is it not working and i found a forum they said that it is because of direct x "9.0b". If you have a direct x 9.0b on your computer you will be able to upgrade it to 9.0c because there is a bug. what i did is searched for an OS (Operating System), of course XP which has a direct x 9.0c because if you have this the copy of your OS is updated so you will not be having a trouble connecting your phone, bt and pc suite. for those people having problems with connections try this hope it will help you guys!!!
goodluck!!!!
