Virus I guess on my nokia3230
2 replies · 2,078 views · Started 11 December 2005
I think i have virus on my MMC. I have to mmc's a 1GB MMC and a 32MB MMC. The 32MB MMC works fine but a week after buying my 1GB MMC it stopped working. Here is a list of things i CANT do.
Delete Files
Format Disk
Install programs
Uninstall programs
Move files
Take picturse (Camera)
Record sounds
Change anything
Make gamescores.
NOTHING!!!! ONly use programs, call ppl, send sms its like im having a 2110!! with colors.
I scanned my 32MB And no virus found. So I switched to my main MMC which has 1GB and which i want to use and which has the virus.
I tried to scan it. It only scanned my C: so i put custom scan on E: info: "No files found".
Then i go to Fexplorer and find out there are 3 programs installed on E: Why wont it scan them. Help!
I dont have a MMC reader so I'm asking, will MMC reader's be able to format memorycards no matter what! Since my phone is fighting so hard against me, if i try to format it will crush and i need to remove/insert battery.
HELP!
-Joppe
Ur MMC is corrupt. Find some posted about "Corrupted MMC Fix". U gonna need a card reader for it otherwise try to format ur MMC with Digital camera but I ain't sure.
