.mov converting problem
4 replies · 2,169 views · Started 17 January 2002
I can not convert .mov to .nim with the converter pro 1.0 built 11.
I can view the file but after converting the video data I am getting a "Internal Error" message.
Do you know what to do?
Hmmm.. have you tried running it through Virtual Dub first to create an MPEG or AVI and then convert that?
Yes - you'll find a link to it on my site - in the links section or hints & Tips (which might also be worth a visit if you have never used VirtualDub before).
Have fun
