Hi chaps,
Does anyone knows why when I try to download a non original copy of TT5 with Nokia PCsuite into my N70 an error message appears saing that it only allows RAJ_S files onte the phone?
Do I need to switch off some protection on the phone?
Cheers
Mark
Download problems TomTom 5
Have you been able to install other program on to the phone?
If not then the security setting allowing installation of programs maybe off. Check settings. (Sorry can't remember exactly where).
BTW not sure what you mean by TT5 non original.
markthebull wrote:Hi chaps,
Cheers
Mark
You need to buy an original copy of TomTom,
Jumping on a different forum to ask the same question still won't help you,
markthebull wrote:From Pocketgpsworld
Sorry for the previous post it is just a fart " a posh one"
http://www.pocketgps.co.uk/
Carl,
