I currently have a Nokia N70 and bought this phone primarily to use with TomTom Mobile sat-nav software but I have experienced many of the problems documented elsewhere on this forum.
As my N70 is practically useless for the purpose for which it was bought, I was considering changing to the Nokia N90, which according to the TomTom website, is supported.
Has anyone seen this phone and if so how does the screen size compare with the N70? TomTom is just about legible on the N70 screen but I wouldn't want to us it on anything smaller.
Regards,
Scott
According to TomTom is also the n70 compatible with TomTom. Why I don't know, because there still is som issues...
They updated there compability list the other day, without following up with a update of course.
I wouldn't dear to by n90, until I have had the opportunity to test it myself. Bet it got the same problems.
http://www.tomtom.com/products/features.php?ID=69&Language=1
Please "nag" tomtom with mails everyone. This isn't good enough!
Is any body who can help me with, how to size the wallpaper of my nokia N70 to show as a full size??
currymonster wrote:I currently have a Nokia N70 and bought this phone primarily to use with TomTom Mobile sat-nav software but I have experienced many of the problems documented elsewhere on this forum. As my N70 is practically useless for the purpose for which it was bought, I was
The N70's problems were only with v2.x firmware, which had numerous Bluetooth bugs. v3.x and above works very well. I've had not a single crash with TomTom Mobile 5.
What firmware are you on?
Steve Litchfield
