I finally got my phone back (nokia 3650), and i went through the trouble of buying a memory card reader/writer.
i can only copy music and videos only in 3gp format or ra and rm format. but my phone cannot read sis files or jar files from the memory card.
i want to start playing mp3 formats on my phone because the quality is much better. and i want to start playing games on my phone aswell.
can somebody pls help me out?
because i dont want my memory card to go to waste.
joejexy wrote:I finally got my phone back (nokia 3650), and i went through the trouble of buying a memory card reader/writer. i can only copy music and videos only in 3gp format or ra and rm format. but my phone cannot read sis files or jar files from the memory card.
[FONT="Times New Roman"]hi there joejexy, its kinda confusing why ur phone won't read sis or jar files... do u use a file manager like the freeware app FExplorer? could u make the case more clear by telling some more info. if u haven't got the FExplorer, its one case and if you've got the FExplorer, its another case.
tc.[/FONT]
i haven't got the fexplorer on my phone because i dont have a data cable or bluetooth dongle or infrared kit to install it anyways.
ive spent all my money on the memory card reader
how can i install fexplorer with memory card reader only
please help
thanks a lot
joejexy wrote:i haven't got the fexplorer on my phone because i dont have a data cable or bluetooth dongle or infrared kit to install it anyways.ive spent all my money on the memory card reader
please help
thanks a lot
[FONT="Arial"][SIZE="3"]hey there.. since u haven't got a bt/ir kit, i can only give the system files to u. u just have to copy it to the mmc. then u will have the FExplorer (this is freeware app that's y im doing this. Or else, it'll be illegal.). u jus have to unzip the files of the folder and paste it in F:\System\Apps\FExplorer (u have to create the folder FExplorer.) then voila. its installed.
(*F: is my drive letter for the mmc thru the mmc card reader. if its different for u, change it.)[/SIZE][/FONT]
FExplorer.zip (55 KB)
i did what you told me to do and voala it was installed,
the fexplorer icon was on the main menu when i put my memory card back into my phone.
thanks anyways 😉
does anyone know how to install ngage games on the nokia 3650 ???
please help
because i finally got FExplorer on my phone
thanks
been tryin to do that 4 a week straight
absi wrote:[FONT="Arial"][SIZE="3"]hey there.. since u haven't got a bt/ir kit, i can only give the system files to u. u just have to copy it to the mmc. then u will have the FExplorer (this is freeware app that's y im doing this. Or else, it'll be illegal.). u jus have to unzip the files of the folder and paste it in F:\System\Apps\FExplorer (u have to create the folder FExplorer.) then voila. its installed.(*F: is my drive letter for the mmc thru the mmc card reader. if its different for u, change it.)[/SIZE][/FONT]
i have done that...but when i replace the memory card back to phone i cannot find the program..so could u pls tell me after copying it to the memory card what shall i do...?? thanks alot
hy dude...
i suggest u to copy your stuff in the phone and after that copy it to your card it should go the prblm is with istalations but maybe if you try it with fexplorer i could go. or maybe you didn't buy a good mmc and therefor its not compatible.
good luck.
