New 9500...
3 replies · 1,808 views · Started 16 December 2005
well hopefully Santa is going to deliver a nice shiny new Nokia 9500 to me for Christmas 😊
Anyway, I was just wondering, I currently have a 9210i with a 128mb MMC in.
What should I go for with the 9500?? What the max size it can take and does it support SD??
I also had the GPS attachment for my 9210i, is there any such thing for the 9500??
Thanks guys,
-Wills 😊
dont know about GPS...but 1Gb is a good size MMC which works stabily...2GB is also supported..but the system sometimes becomes a bit unstable, i've heard..
I think I'm right in saying the GPS doesn't work. I think most people have now swicthed over to Bluetooth GPS's.
wills54321 wrote:I also had the GPS attachment for my 9210i, is there any such thing for the 9500??
The Nokia GPS for the 9210/i will not work on the 9500 as it has the wrong connector, New Nokia's have the pop-port connector,
You could get the Nokia BT GPS or one of the many others that available,
Just a note, If you decide to get TomTom Mobile 5, then it comes with it's own BT GPS and TomTom is not available as software only, So this could be an easy way to get a BT GPS, which also works with other software (I've used it with MapView GPS II),
Carl,
