Palm storage for Nokia 7650
4 replies · 2,372 views · Started 17 November 2002
Hello
I tried loading my pictures on my Palm via IR port. It worked. I can send them back and forth between Palm and 7650, since Palm knows about JPG format. I was wondering if I could the same with SIS files. Anybody tried that?
I used a small utility called forward, which allows me to send files via e-mail, BT or IR. However, I cannot send ANY file, just files received with a message.
Search for an application called "ExBox". It's a utility to register unknown extensions such as SIS or MID and uses a database file of its own to store. You can beam SIS files to your Palm after registering the SIS extension, organize them by folders etc..
