Hello,
We are going to release a new player with equalizer for Series 60 and we'll be happy to receive your comments for beta version:
http://www.alonsoftware.com/downloads/AlonAudioRecorder_s60.SIS
The most active people will be able to get the registration keys 😊
Please, test the following features:
- Playing MP3, OGG and WAV files;
- Equalizer for all supported audio formats
- Recording function (record MP3 and WAV files)
The short description:
For playback:
The menu is assigned by software buttons.
Choosing button "List" you may select the folder for playback
For recording:
If you choose Settings>Defined by user, your file will be record at the same folder which has been chosen for playback If you switch off "Defined by User", you may select the folder by choosing Record folder by the left software button.
Equalizer:
To switch to the equalizer choose the button "EQ".
3 independent equalizers are switch on by hardware buttons 1, 2, 3. They are tuning by "Pen"+Joyctick and "Pen"+C.
hello, here some suggestions made on my 6630 😊
first it shouldn't play every marked playlist item immediately, because this makes the browsing of the playlist while playing a song really disgusting (file access delay + quickly changing music)
then truncating the filenames on the left is also not so ideal. maybe you can truncate it at the middle of the filename or you can just let it scroll around?
compared to oggplay there is missing the ability to define hotkeys and to fast forward/rewind within a track.
a nice idea from wmaplus! is a volume boost. if this is also possible with your EQ without any disadvantages could you please add some good predefined settings for it. the typical customer gets easily bored when he has to adjust too many things...
Hi! Guys! This is great app. initially this is what i want to change/add if possible..
1. Instead of VU Meter an Spectrum Analyzer same in OGG player will be much better.
2. The equalizer looks difficult to adjust if somebody not familiar with (Not user friendly) better if you will include presets and also manual tuning. But the interface will be better if you can make 5 bands or 3 Bands only with vertical adjustments let say 10Hz, 3 Hz, 1KHz, 3Khz, 10Khz or only Bass, Mid, Treble. So only joystcik can adjust these easily.
3. A Help in About will be helpful to know the controls of the software and how to use it.
That's it from now...
Once Again...Yes indeed Hotkeys are needed. I have also noticed i am using N6630 when playing music somehow the backlight is not turning off which can drain the battery in a short period of time. One more also please make an option to edit in the playlist so that the user can remove music they don't want to play. Please check....thank you...
Hello,
Thanks for your comments.
We've released MP3 Player with equalizer but without recording feature. We are going to release Recorder as a separate product in the future.
Please, test the Player:
http://www.alonsoftware.com/downloads/alonmp3player_s60.sis
We've took into account some of your comments:
- the posibility of rewind ("Pen"+joystick)
- an opportunity of remove, delete and rename of tracks
- the opportunity of choosing folder and all subfolders for playback.
That's more like it ONLY an MP3 player with EQ...coz one time i accidentally recorded a sound when i listen to it was very bad (sorry) you cannot understand the recorded audio. Anyway i prefer only a player without a recorder😃 an equalizer is a big factor:icon14:
when i installed it on my 6630 and started to record my phone froze and when i restarted i had a message "memory full to perform operation" although i didnt do anything,and then i had to format the phone.i dont know maybe its because the phone was s.....d up or my firmware is too old
v2.39.15
11-11-04
Rm-1
Hello,
Thanks for your comments, we've tried to consider some of them in our ALON MP3 Dictaphone:
http://www.alonsoftware.com/downloads/alonmp3dictaphone_s60.sis
Also, we've released new version 1.15 of ALON MP3 Player:
What is new:
- hot buttons
- fast rewind
- pause/resume playback during/after incoming calls
If anybody wants to help us to translate those products, please, contact us: [email][email protected][/email] and he will receive the registration key
You may try new version of ALON Audio Dictaphone 1.15
with M3U Playlists. Now you may both use Winamp playlists on your smartphone and use playlists created on your smartphone at Winamp.
If anybody would like to help us to translate app to his language (especially French, German, Spanish), please contact us: [email][email protected][/email]
and you will receive registration key 😊
