Alternative Fonts
3 replies · 1,304 views · Started 17 December 2005
There is someone that have customized his X with some different font?
Which are your favourites?
I'm looking for suggestions! 😃
I use the default fonts 😊 I haven't used any custom fonts... i like the standard. Anyway: Does someone how to customize them?
All you've to do is to put the *.GDR file into the folder "X:\SYSTEM\FONTS" (it's the same if you create it on "C:" or on "E:"😉
To personalize the font i used "Easy GDR creater", even if it's in korean (i think) it's very easy to understand how it works.
Is impossible to remove the font while in use, but if you rename the folder the problem does not occur.
Bye! 😊
