ogg player
21 replies · 9,985 views · Started 17 December 2005
steff2632 wrote:is the writer of ogg player planning on making an update that is compatable with the n70??
OggPlay 1.65 works fine on my n70.
its freeware isnt it??can you post your version on here beacause my version of 1.65(unstable version) & 1.62(stable version) just crash & leave symbina os hanging. WSOD
steff2632 wrote:its freeware isnt it??can you post your version on here beacause my version of 1.65(unstable version) & 1.62(stable version) just crash & leave symbina os hanging. WSOD
Wow, this web site is so slow I can barely stand it.
I tried to attach the OggPlay zip file I have, I think I got it off the OggPlay website, but this site is so slow when I hit "Manage Attachments" it either times out or I get a vbScript error on the button.
Pm me if you want it.
And are you sure you have never loaded a xxxPDA release of software? If you have, OggPlay and SmartProfiles will never work until you reformat your phone or clean up the "extra" files xxxPDA releases place on your hard drives of the phone.
ive only tried to install the versions from this site http://symbianoggplay.sourceforge.net/ i tried the s60 mmf version havent tried the other one
steff2632 wrote:ive only tried to install the versions from this site http://symbianoggplay.sourceforge.net/ i tried the s60 mmf version havent tried the other one
No, I don't mean cracked versions of OggPlay because it's free.
Have you installed any cracked app? If you have, OggPlay as well as other s60 apps will fail on n70.
i know there aint any cracked versions i meant thats the only site that i have got off play from. all my other apps work apart from fscaller which kills 'go to' but other than that they are all fine
EinZtein wrote:Wow, this web site is so slow I can barely stand it.
you said that you tried as a .zip try it as a .sis
Here is the OggPlay file that I installed on my n70. It works great on mine, use at your own risk though.
I've been testing this beta version 1.66 on my n70 and it is working very well.
Attachments: OggPlay166beta.zip (202 KB)
Updated file to beta version 1.66, which is working well on my n70. This is also suppose to work on n90.
If you check the OggPlay forums there's at least one happy N90 user 😊
The only issue with the N90 is that OggPlay doesn't support double resolution skins, yet. That's coming in 1.67...
steff2632 wrote:thanx EinZtein only problem i have now is that my .ogg files are the same or bigger than my mp3s!
Here are the settings I use in "Goldwave" to do batch conversions to ogg, small files that sound real good on my n70. I tried other settings but these seem to work with all music files without erroring out.
Convert to Ogg format:
Vorbis/Ogg 1.0.1 codec 32000Hz, 24kbps (-0.1q), mono
I added the filter to "Remove Hiss", "Reduce Hum" and increase volume to 150%.
Files are crystal clear and are under a 1 meg each.
EinZtein wrote:Updated file to beta version 1.66, which is working well on my n70. This is also suppose to work on n90.
IN the Oggplayer website there is no reference (at least I have not found it) to any 1.66 version. Last stable version mentioned is 1.6.5.
Where have you downloaded it?
Talonso wrote:IN the Oggplayer website there is no reference (at least I have not found it) to any 1.66 version. Last stable version mentioned is 1.6.5.
From a beta tester.
on the soureforge(or however it spelt!) website there is a link to forums & in the help section of the forum there is a thread about the n70 & oggplay.its been continually updated. lastest version is from around december sometime
is there a way to set oggplay as the defualt player of .oggs & mp3s?at the moment its the normal music player & real player that load when i press on a file
Baadshah555 wrote:GOOD, Hey Will this OGG player work properly on Nokia N70
I've tried Ogg Player 1.65 on my N70 and it was working fine.
