Nokia 3230 questions
5 replies · 2,610 views · Started 18 December 2005
Hello, I'm new in this forum and I've got several questions about my new Nokia 3230. The first is how can I send large size files from my phone to someones phone via IR ot BT? I already have heard about MsvDriveE and I use it on my phone but I still can't send from my phone to another phone large files althought either my or his have MsvDriveE. Help pls thats a big problem for me. The other problem is that I can't instal games using my camera... When i took my phone it had a game called Killer Virus and it works fine. It uses the camera and it works but every other game using the camera that I have installed doesn't works. Pls help...... Thanks
Hi, I am also new to this forum & have recently bought a 3230. I'm sorry I can't help you with your question but I noticed that you have installed other games to the phone. You may be able to help me, I have sent via PC suite a game to the phone, went into app. manager and it was there, went options & installed it, had the message saying it's installed but it is not listed under games in the normal menu. Is there something else I have to do or will I find the game somewhere else in the menu, I have searched every where but can only find it in the App. manager and it is listed as installed. Any help would be greatly appreciated.
May I know what kind of file that u try to sending (.jpg/.3gp/.sis/etc - the extension)? The size? Got any error msg?
U means that a game that using ur phone's camera, right? AFAIK, running a camera (even game) will take much of ur phone's memory (RAM) so I suggest u to compress ur memory (using FExplorer app by GoSymbian for example) and close (exit) every opening apps at 1st befora running that camera game.
As my experience, u've installed the app without removing it 1st (replaced installation) and default installation doesn't go to under 'Games' directory (menu+game+'the game) but under root/menu directory (menu+ 'the game). But u could also trying to restart ur phone after installation or try to open the game (game_name.app) under c:\system\apps\game_name\*.app or e:\system\apps\game_name\*.app (on MMC) using FExplorer.
Keep me inform :wink: .
rulirahm: May I know what kind of file that u try to sending (.jpg/.3gp/.sis/etc - the extension)? The size? Got any error msg?
I am having the same problem sending large size files to other phones via BT and IR.
I tried sending .3gp files and could only send files with size less than 5mb and when tried to send files of size more than 5mb, received an error "Not enough memory to perform operation. Delete some data first"
you need to install MsvDriveE so you can send files direct to the memory card. do a search for it. (cannot remember where i found it) but i found it quite easy by googling
Recently, I've the same problem with u. Finally, my friend told me that Nokia 3230 internal memory is 6mb. It's normal that u can only send a file almost with 6mb size (5mb). I've no idea. Card reader is the answer by me right now.
